Modify a deployment#
You can change deployments through Lens K8S IDE. To modify a deployment:
- Connect to the cluster from Catalog > Clusters.
- Navigate to Workloads > Deployments through the left panel.
- Right-click on a deployment and select Edit in the right column.
Edit the deployment
.yamlfile and click Save and Close.
