Port forward traffic from a Kubernetes pod#
Port forwarding in Kubernetes is a method that establishes a temporary connection between a local machine and a specific pod or a container. This connection enables local access to a service that runs within the pod or container. The port forwarding procedure simplifies debugging and facilitates the real-time monitoring without exposing services and data to the public internet.
In Lens K8S IDE, you can port forward without using the kubectl command-line tool:
  1. From the Pods tab of the cluster view, click on a pod.
  2. In Pod Details > Container, select a container with configured ports.
  3. Select one of the following options:
    • 8000/TCP to randomly assign the port and open a browser.
    • Forward to configure the parameters in the dialog menu.
See the video tutorial on our YouTube channel:
Managing port forwarding sessions#
You can see available port forwarding sessions in the Port Forwarding tab where the brief information about the sessions is displayed. You can also open a port forwarding in the browser, edit, stop, or delete the port forwarding session.
See also
Adding clusters to Lens K8S IDE
