Cluster settings#
To open the Settings menu, click the cluster icon in the cluster view. You can set various configurations such as cluster name, proxy server, vulnerability scanning, and others.
In a cluster tab, open Settings with:
  • Ctrl+Shift+T for Linux and Windows
  • Cmd+Shift+T for macOS
The following menus enable you to set various configurations of the cluster.
Cluster configurations
Submenu Description
General This menu contains the following options:
  • Cluster name. Type cluster name into the Cluster Name input field.
  • Cluster icon. You can upload several file formats such as .jpeg, .png, .svg, and change the color of the default icon.
  • Path to kubeconfig. The Kubeconfig field contains the link to the cluster kubeconfig.
Proxy This menu contains an HTTP Proxy address for communication with the Kubernetes API.
Terminal This menu contains the following options:
  • The initial directory for the Terminal. Specify the path in the Starting Working Directory input field.
  • The default namespace for kubectl. Specify the namespaces in the Default Namespace input field.
Namespace This menu contains the list of namespaces that you have access to. The option is useful when you do not have permission to list cluster namespaces. Specify namespaces in the Accessible Namespaces field.
Metrics This menu contains the following options:
  • Metrics Source. Select the source from the drop-down list.
  • Telemetry exceptions by Kubernetes cluster objects. Select Kubernetes cluster objects in the Hide Metrics from the UI drop-down list.
Lens Metrics This menu contains the following options:
  • Timeseries data visualization. Toggle Enable bundled Prometheus metrics stack to switch the option.
  • Metrics generating service. Enable kube-state-metrics only if there is no an installed instance of the service. Toggle Enable bundled kube-state-metrics stack to switch the option.
  • Prometheus metrics exporting service. Enable the Prometheus Node Exporter only if there is no an installed instance of the service. Toggle Enable bundled node-exporter stack to switch the option.
Node Shell This menu contains the following options:
  • Node shell image. Specify the node shell image in the Node Shell Image input field.
  • Pre-existing secret. Specify a pre-existing secret in the kube-system namespace in the Image Pull Secret. This setting is optional and used for pulling an image from a private registry.
See also
Adding clusters to Lens K8S IDE
