Details panel#
The details panel provides details about cluster objects, expanding the information displayed in views.
You can find options available to the cluster object on top of the panel. The set of actions differs for each type of cluster resources. You can find more information about options for the cluster object on the corresponding documentation page. However, the following options are common for all resources:
Copy
Copies the resource name.
Edit
Opens the resource config file.
Delete
Removes the resource.
Watch the example of details panel in the video below:
