Port-forwarding in Lens K8S IDE Kube#
Warning
This functionality is scheduled for deprecation. We recommend planning for its removal.
Lens K8S IDE Kube provides automatic port-forwarding, so there is no need to complete the steps described in Port forward from a Kubernetes pod.
If you have an application running in a pod of your LDK cluster, you can access it in your browser at http://localhost:<port-number>. Specify the port number in the nodePort field of the corresponding NodePort service. The following example sets the port to 30036, so you can open the application at http://localhost:30036.
apiVersion: v1
kind: Service
  selector:
    app: my-app
    type: NodePort
    ports:
    - name: http
      port: 80
      targetPort: 80
      nodePort: 30036
      protocol: TCP
To create a new service, see Create resource from a template.
